[Proj] towgs84 functionality
Tue Mar 18 12:12:19 PDT 2008
Jeff Huber wrote:
> I'm new to this, so here is a, hopefully, simple question.
> Why don't I get a shift when I use towgs84 in the following:
> invproj +proj=utm +ellps=krass +x_0=500000 +y_0=0 +lat_0=0 +lon_0=75
> +k=.9996
> 701176.9 7550769.7
> 79d48'58.181"E  67d59'57.701"N
> Expected to get +79.8161616,     +67.9993614  so that one is OK
> invproj +proj=tmerc +ellps=krass +towgs84=28,-130,-95 +x_0=500000 +y_0=0
> +lat_0=0 +lon_0=75 +k=.9996
> 701176.9 7550769.7
> Expected to get +79.8149530,     +68.0000817  but did I get same answer
> as above
Jeff,
The invproj command converts between projected coordinates and geographic
coordinates *on the same datum*.  The towgs84 value is only used when you
change datums.   You can do that with the cs2cs command.
eg.
cs2cs +proj=utm +ellps=krass +x_0=500000 +y_0=0 +lat_0=0 +lon_0=75 \
       +k=.9996 +towgs84=28,-130,-95 \
       +to +proj=latlong +datum=WGS84
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
