[Proj] projection adding request
Wed Mar 19 18:57:27 PDT 2008
Oliver Christen wrote:
> I would like to know if there is a procedure to ask for a projection
> definition to be added to the epsg file distributed with the proj package.
Has the projection already been added to the EPSG database? If not,
you can submit a change request via:
	http://www.epsg.org/Comms/Comment.asp
