R: [Proj] cs2cs usage
Thu Mar 20 14:52:41 PDT 2008
Marco Pasetti wrote:
> Hi all,
> I forgot in the previous mails:
> 1) is there a way to *pass* the input latitude and longitude coordinates to
> cs2cs command, without type them at command prompt?
Yes
> 2) can the cs2cs command write the *results* in an output file?
Yes
In particular cs2cs works as a filter.  It's input can be redirected from
a file, and it's output can be redirected to a file.
cs2cs {parameters}  < input.txt   > output.txt
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
