[Proj] Transverse Mercator algorithm
Irwin Scollar al001 at uni-koeln.de
Tue May 27 01:57:52 PDT 2008
A way to speed up TM calculation with enhanced accuracy was published
by Knud Poder in 1989:
Implementation of Co-ordinate Transformations. NKG Nordiske
Forskarkurser, Ebeltoft September 1988, Moderne Teknik i Geodaesi og
Opmaling, 243 - 280. Kort & Matrikelstyrelsen, Copenhagen 1989.
It uses Clenshaw summation for the series expansions. See also
Tscherning & Poder:
http://cct.gfy.ku.dk/publ_cct/cct80.pdf
Clenshaw summation can be applied to almost any algorithm containing
series expansions to gain speed.
As far as accuracy is concerned, analysis of this should also take
into account the limitations of floating point processing when a 32
bit machine is being used.  This is not a problem with 64 bit
hardware and compilers.
For a real-time tracking application, I coded with the native 10 byte
extended IEEE Floating Point representation available in Intel and
compatible processors and offered by some compilers rather than the
double precision used in much published code.  Howevere, the hardware
support in the processor may be slowed by cache misses due to non-4
byte boundary conditions on some machines. Higher speed at the
expense of accuracy might perhaps be obtained by using SSE
instructions via one of the Intel compilers or with hand-coded
assembler for SSE4, but I haven't tried it.
Irwin Scollar
