[Proj] Problem overlaying georeferenced images in Google, Maps(projection problem!)
support.mn at elisanet.fi support.mn at elisanet.fi
Sat May 31 01:44:48 PDT 2008
More ideas...
The huge north shift, which is visible in your pictures,  is usually due
to the conversion between spherical and elliptical. There is a way to
go around that, but how it should be done in your case.... ???
Regards: Janne
>Now, the results in Google Earth:
>The image before reproyecting (UTM zone 30 datum ED50)
>http://www.nebulared.com/tmp_geo/Balearic_Island_UTM_ED50.png
>The image reproyected
>http://www.nebulared.com/tmp_geo/Balearic_Island_Reprojected.png
>What's the problem?:
