[Proj] Any access to geodetic[sic] functions ??
Hamish hamish_b at yahoo.com
Mon Nov 17 01:24:08 PST 2008
Gerald I. Evenden wrote:
> Ok, you asked for it.  The inverse problem:
> /* Translation of NGS FORTRAN code for determination of true distance
> ** and respective forward and back azimuths between two points on the
> ** ellipsoid.
cheers, this will be most useful.
for the sake of satisfying the issues of the parallel licensing thread,
it must be asked under which (if any) licensing terms you post this code
beyond the original NGS public terms.
I would also ask, if the intention of posting this code to the PROJ.4
FAQ is to create a reference implementation of the inv. geodesic "gold
standard" in C/Python/Javascript/LEGO lang/etc. for the greater good
of humanity (or to at least slow down the propagation of poorer methods,
and their results), then should Pittman's version be pursued next?
  http://thread.gmane.org/gmane.comp.gis.proj-4.devel/3361/focus=3366
Hamish
