[Proj] Datum shift for Dutch maps 1850-2000
    Frank Warmerdam
    warmerdam at pobox.com
    Wed Nov 26 07:56:09 PST 2008
Jan Hartmann wrote:
> Well, changing the ellipsoid seems to help. The ellipsoid that is
> officially documented for this map, and the one I have been using has
> +a=6376950.4 +rf=309.65.
> This gives the 650m Nord shift. Replacing this ellipsoid by the Bessel
> ellipsoid (a=6377397.155, rf=299.1528128) gives a 50m South shift.
> Again, I am reprojecting to the present projection which has a Bessel
> ellipsoid. I can see that the first ellipsoid has a significantly
> smaller semi-major axis than the second one. Does this explain the  Nord
> shift?
Jan,
A large north-south shift would be consistent with proj.4 attempting an
automatic datum change via the ellipsoid (converting from latlong on one
ellipsoid to geocentric, and then to lat/long on the other ellipsoid).
Best regards,
More information about the Proj
