[Proj] Bit curious about +ellps
Emmanuel Séguin emmanuel.seguin at ign.fr
Thu Nov 27 06:28:13 PST 2008
I'm currently using proj registry file (epsg) for building a little library.
Therefore i do have a question regarding the +ellps tag.
Some projections have a +a and +rf or +b tag (defining the ellipsoid) and
some projections are using the +ellps tag. I assume that projections defined
with the +a and +rf/+b tags are relying on uncommon ellipsoid definitions.
But what I find a bit peculiar considering the way proj is relying on
registry/dictionnary files is that ellipsoid definitions used by +ellps are
actually stored into pj_ellps.c.
Wouldn't it be more transparent for users to have an ellipsoid
registry/configuration file ? Or am i completely wrong here ;) ?
Manu discovering proj4
View this message in context: http://n2.nabble.com/Bit-curious-about-%2Bellps-tp1585382p1585382.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
