[Proj] google KML API advice sought
Jan Hartmann j.l.h.hartmann at uva.nl
Fri Nov 28 03:06:54 PST 2008
Roger Oberholtzer wrote:
 > what might be a good choice for the generic projection to use that >
 > would do this best in proj (I am still using 4.4.9...)?
Hi Roger,
Just an aside, if possible, upgrade to the latest version of PROJ
(4.6..) or you'll come to grief over datum shifts. Can't you use the
projection Google uses itself for its maps (+proj=merc +a=6378137
+b=6378137  +lat_ts=0 +lon_0=0 +k=1.000000 +x_0=0 +y_0=0 +units=m
no_defs +nadgrids=@null)? This is a spherical Mercator projection based
on the WGS84 Datum. You need to apply a correction to compute real
distances, as Mercator maps get distorted towards the North/South Poles,
but that is a very simple formula I believe.
Jan
