[Proj] GeoTiff <-> Proj.4
support.mn at elisanet.fi support.mn at elisanet.fi
Wed Oct 1 07:08:12 PDT 2008
Hello,
There is no general rule how to map GeoTiff GeoKeys to proj.4
parameters (or is there?) Every projection has it's own mapping?
Can I write "lat_ts" instead of "lat_0" ??
Is there "lon_ts"?
Here I have those keys I have found some mapping,
but how about the others. Must be different for each
projection?
ProjLinearUnitSizeGeoKey	3077 in meters
ProjStdParallelGeoKey		3078 in GeogAngularUnit -> lat_1
ProjStdParallel2GeoKey	3079 in GeogAngularUnit -> lat_2
ProjOriginLongGeoKey		3080 in GeogAngularUnit  -> lon_0
ProjOriginLatGeoKey		3081 in GeogAngularUnit  -> lat_0
ProjFalseOriginLongGeoKey	3084 in GeogAngularUnit
ProjFalseOriginLatGeoKey	3085 in GeogAngularUnit
ProjCenterLongGeoKey	3088 in GeogAngularUnit
ProjCenterLatGeoKey		3089 in GeogAngularUnit
ProjFalseEastingGeoKey	3082 in ProjLinearUnits -> x_0
ProjFalseNorthingGeoKey	3083 in ProjLinearUnits -> y_0
ProjFalseOriginEastingGeoKey	3086 in ProjLinearUnits
ProjFalseOriginNorthingGeoKey	3087 in ProjLinearUnits
ProjCenterEastingGeoKey	3090 in ProjLinearUnits
ProjCenterNorthingGeoKey	3091 in ProjLinearUnits
ProjScaleAtOriginGeoKey	3092 in ratio   -> k_0
ProjScaleAtCenterGeoKey	3093 in ratio
ProjAzimuthAngleGeoKey	3094 in GeogAzimuthUnit -> alpha
ProjStraightVertPoleLongGeoKey	3095 in GeogAngularUnit
ProjRectifiedGridAngleGeoKey	3096 in GeogAngularUnit
Regards: Janne.
