[Proj] GeoTiff <-> Proj.4
Gerald I. Evenden geraldi.evenden at gmail.com
Wed Oct 1 08:40:06 PDT 2008
On Wednesday 01 October 2008 10:08:12 am support.mn at elisanet.fi wrote:
> Hello,
> There is no general rule how to map GeoTiff GeoKeys to proj.4
> parameters (or is there?) Every projection has it's own mapping?
> Can I write "lat_ts" instead of "lat_0" ??
lat_ts denotes latitude of true scale while lat_0 generally refers to latitude
of origin.  One should *never* assume that they create the same value.
> Is there "lon_ts"?
I have never used it. "Longitude of true scale" is a meaningless term.
> Here I have those keys I have found some mapping,
> but how about the others. Must be different for each
> projection?
> ProjLinearUnitSizeGeoKey	3077 in meters
> ProjStdParallelGeoKey		3078 in GeogAngularUnit -> lat_1
> ProjStdParallel2GeoKey	3079 in GeogAngularUnit -> lat_2
> ProjOriginLongGeoKey		3080 in GeogAngularUnit  -> lon_0
> ProjOriginLatGeoKey		3081 in GeogAngularUnit  -> lat_0
> ProjFalseOriginLongGeoKey	3084 in GeogAngularUnit
> ProjFalseOriginLatGeoKey	3085 in GeogAngularUnit
> ProjCenterLongGeoKey	3088 in GeogAngularUnit
> ProjCenterLatGeoKey		3089 in GeogAngularUnit
> ProjFalseEastingGeoKey	3082 in ProjLinearUnits -> x_0
> ProjFalseNorthingGeoKey	3083 in ProjLinearUnits -> y_0
> ProjFalseOriginEastingGeoKey	3086 in ProjLinearUnits
> ProjFalseOriginNorthingGeoKey	3087 in ProjLinearUnits
> ProjCenterEastingGeoKey	3090 in ProjLinearUnits
> ProjCenterNorthingGeoKey	3091 in ProjLinearUnits
> ProjScaleAtOriginGeoKey	3092 in ratio   -> k_0
> ProjScaleAtCenterGeoKey	3093 in ratio
> ProjAzimuthAngleGeoKey	3094 in GeogAzimuthUnit -> alpha
> ProjStraightVertPoleLongGeoKey	3095 in GeogAngularUnit
> ProjRectifiedGridAngleGeoKey	3096 in GeogAngularUnit
What a mish-mash of terminology.  That is why I believe that the equations for
the projection should be mandated as part of any projection description
because they resolve the usage and meaning of control contants.
And I suspect that the above often have different "flavors" of description in
French, German, Italian, Russian, Chinese, etc..  Again, the mathematical
description is the only lingua franca of the definition.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
