[Proj] Terminology for origins
    Clifford J Mugnier
    cjmce at lsu.edu
    Fri Oct  3 08:18:48 PDT 2008
In North Africa, several of the Grids also have a False Northing at the False Origin in order to avoid negative northings.
Really!
Snyder's terminology explicitly referred to Grids only in the United States and used by the U.S. Geological Survey.  Others have adopted his terms and mistakenly applied them to other countries and regions.  For the most part, the old British General Staff, Geographic Section from WWII really defined practically all of the components of existing Grids.  When Snyder had questions about large-scale coordinate systems, he commonly referenced me.  For the proper terminology in English, I'd defer to the current British Military Survey as the final authoritative source.  The U.S. Military has really cobbled up an awful collection of erroneous terms.
Lord help you for the equivalent terms in other languages ... French is a particular zinger because their terms seem to have zero relation to the English terms.  Castilian Spanish would likely be a similar enigma.
For instance, the original uses for the following terms were:
Grid - Aphylactic projections ( Cassini-Soldner, Polyhedric, Polyconic)
Zone - Lambert Conformal Conic & Ellipsoidal Bonne
Belt - Transverse Mercator
Cartesian systems for the Oblique Mercator, the Krovak, the Rosenmund, the Hatt did not have explicit terms.
Since then, such things have eventually been considered to be synonomous.  Once upon a time, they were not.
Cliff Mugnier
LSU
From: proj-bounces at lists.maptools.org on behalf of Mikael Rittri
Sent: Fri 03-Oct-08 03:34
To: geraldi.evenden at gmail.com; PROJ.4 and general Projections Discussions
Subject: [Proj] Terminology for origins
Is there a simple and accepted standard terminology for the various kinds of projection origins?
Gerald wrote:
> First, I detest the term "natural origin."
Me too.
> It seems to be synonymous with the basic mathematical origin. "Natural" is an unnecessary adjective
I agree that it is the wrong adjective.
> and just the term origin should suffice.
Should suffice, but doesn't, since the point with Easting and Northing both zero is also a kind of origin.
I think there used to be a simple and wide-spread terminology before EPSG became so influential, like this:
  * False Origin: the point whose projected coordinates are both zero.
  * True Origin: the point whose projected coordinates are False Easting and False Northing.
The words "True" and "False" are perhaps somewhat strange, but this terminology is used, for example, by:
  - http://www.mered.org.uk/mike/gps/gps_usergrid_more.htm
  - http://www.ordnancesurvey.co.uk/oswebsite/gps/information/coordinatesystemsinfo/guidecontents/guide7.html
  - http://www.colorado.edu/geography/gcraft/notes/coordsys/coordsys.html
  - http://home.clear.net.nz/pages/paulcatc/nzgrid1.htm
  - http://www.dartmouth.edu/~remsense/1-10%20Projections.htm
On the other hand, we have a single but influential source,
  - http://www.epsg.org/guides/docs/G7-2.pdf (EPSG (or OGP) Guidance Note 7.2)
which makes subtle (I say hair-splitting) distinctions. It defines (section 1.2)
  * Grid Origin: the point whose projected coordinates are both zero.
which I can accept, but also that
  * The point whose projected coordinates are False Easting and False Northing should be called
    o "Natural Origin" if it is natural enough in an undefined way, or
    o "False Origin" if it is less natural, or
    o "Projection Centre", if it is not very natural, but not very false either,
    o "Grid Origin", but in a different meaning from the usual EPSG Grid Origin,
         if the other alternatives are not sufficiently confusing ;-)
In practice, it seems that this point is called
    o "Natural Origin" in most projections, but
    o "False Origin" in a Lambert Conformal Conic (2SP) and in a Polar Stereographic Variant C,
    o "Projection Centre" in an Oblique Mercator (plain or non-Hotine variant),
    o "Grid Origin" in a Krovak Oblique Conformal Conic.
The first three lines above follows mostly from Table 3 on page 14.
Krovak is forgotten in Table 3, but in section 1.3.2 on Krovak names the parameters
    FE = Easting at grid origin,
    FN = Northing at grid origin,
even though according to section 1.2, the Easting and Northing at a Grid Origin
have to be zero and are not free to vary.  (In earlier versions of Guidance Note 7.2,
these parameters for Krovak were called Easting/Northing at Projection Centre, but this was
wrong.  In the usual instance of projection, the Projection Centre is east of Slovakia,
but the point with coordinates FE and FN is the oblique cone apex near Helsinki.)
Personally, I prefer the old, simple terminology, but since EPSG has hijacked the
old term "False Origin" to mean "True Origin" now and then, the old terminology
can be misunderstood.
Grid Origin is OK by me, since it cannot be misunderstood (except for Krovak!).
For the point with coordinates (FE, FN), I don't know a really good name.
However, the site http://www.sco.wisc.edu/pubs/wiscoord/summary.php uses
the term
    "Actual Origin"
for this point, which does not conflict with any EPSG term.
Does anyone agree that Grid Origin and Actual Origin are good names?
Mikael Rittri
Carmenta AB
Box 11354
SE-404 28 Göteborg
Visitors: Sankt Eriksgatan 5
SWEDEN
Tel: +46-31-775 57 37
Mob: +46-703-60 34 07
mikael.rittri at carmenta.com
www.carmenta.com
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20081003/5cf0136b/attachment.html>
More information about the Proj
