[Proj] Geocentric Coordinates
Eran Burstain burstain at gmail.com
Mon Oct 6 04:10:31 PDT 2008
Tnx, but how do i do it from code ?
I understand that I should initialize two projections with the
"+proj=geocent +ellps=XXXX" and "+proj=utm +zone=XX +ellps=XXXX" strings,
but then what ?
(Transformation should have 3 points for each input and 3 for each output
with height above ellipsoid, isn't it ?)
On Mon, Oct 6, 2008 at 11:19 AM, Paul Kelly
<paul-grass at stjohnspoint.co.uk>wrote:
> On Mon, 6 Oct 2008, Eran Burstain wrote:
>  Hi !
>> How can I convert geocentric ECEF coordinates to UTM and vice versa ?
> Something like
> cs2cs +proj=geocent +ellps=XXXX +to +proj=utm +zone=XX +ellps=XXXX
> should do it. You might want some datum transformation parameters too
> (+towgs84=X,X,X) depending on your application.
> Paul
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20081006/e8d36047/attachment.html>
