[Proj] Terminology for origins
Mikael Rittri Mikael.Rittri at carmenta.com
Tue Oct 7 02:43:53 PDT 2008
There is a picture of the Sud Algerie Grid on page 4-25 in
http://www1.nga.mil/ProductsServices/GeodesyGeophysics/WorldGeodeticSystem/Related%20Documents/8358_1a.pdf
but the resolution is bad.  One can see that the grid extends farther south than the zero Northing line, though.
I wrote:
> Let me see if I got it right.
but I didn't; the wrap-around occurs where the Northing becomes zero.
Clifford Mugnier wrote (to me):
Sent: den 6 oktober 2008 16:13
To: Mikael Rittri
Subject: RE: [Proj] Terminology for origins
No.  From the Northing being 300 km at the Latitude of Origin, 33ยบ 18' North, going South from there the ordinate would decrease to zero.  At that point, it would then have a "jump" value of 1,000 km and then decrease South from there.  Such things require a logical "IF" to work properly in GIS software.  With most of GIS software being programmed by programmers and not Cartographers or Geodesists, it remains a conundrum.
Likewise, using ellipsoidal Loxodromes for boundaries between various Grids ...  :-)
C. Mugnier
From: Mikael Rittri [mailto:Mikael.Rittri at carmenta.com]
Sent: Mon 06-Oct-08 09:05
To: Clifford J Mugnier; PROJ.4 and general Projections Discussions
Thanks for explaining.  I did not understand that the extra False Northing should be added only south of the False Origin.
[ the rest of my post can be found at http://lists.maptools.org/pipermail/proj/2008-October/003876.html ]
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20081007/aef7a38d/attachment.html>
