[Proj] EPSG:28992 to EPSG:23031 conversion
Wed Oct 8 09:51:15 PDT 2008
Bart van den Eijnden (OSGIS) wrote:
> Hi Jean-Claude,
> I am using PROJ 4.4.9 so that should not be necessary or am I mistaken?
Bart,
It is necessary if ED50 is non-trivially different from WGS84 though my
understanding was that the differences were small.  I personally suspect
the problem is either the sterea projection method (there are several
variations of this I believe) or your towgs84 parameters are not ideal.
Best regards,
