[Proj] Distance calculation
Gerald I. Evenden geraldi.evenden at gmail.com
Tue Oct 14 13:14:44 PDT 2008
On Tuesday 14 October 2008 4:04:48 pm Karl Swartz wrote:
> > Zhang Xue-Lian (1985) The nested coefficient method for accurate
> > solutions of direct and inverse geodetic problems with any length.
> > Proceedings of the 7th International Symposium on Geodetic
> > Computations,  Direct and inverse distance
> > functions.              Cracow, June 18-21, 1985. Institute of
> > Geodesy and Cartography. Wasaw, Poland, ul. Jasna 2/4 pp 747-763
> > since it's more accurate than the classical method due to Gauss for
> > long distances.
> How does this compare to Thomas Vincenty's algorithm (which can be found
> at http://www.ngs.noaa.gov/PUBS_LIB/inverse.pdf)?
>  -- Karl
I second the request as I considered it the gold standard and besides full
documentation and source code are available at NGS as well as online
computational services.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
