[Proj] Distance calculations
OvV_HN ovv at hetnet.nl
Thu Oct 16 08:29:27 PDT 2008
What do I think?
His numerical integration method is way too simple to be practical and he
doesn't address all difficulties like the correct azimuth quadrant and
problems with numerical precision of transcendental functions.
For all geodetic purposes the Vincenty method has proved to be accurate
enough and very efficient.
Note that although a _good_ numerical method can give near arbitrary
precision for the geodesic, the actual earth' dimensions are not known with
greater accuracy than some centimeters, even if a tidal-free model is
assumed.
Oscar van Vlijmen
----- Original Message -----
To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Sent: Thursday, October 16, 2008 4:04 PM
Subject: Re: [Proj] Distance calculations
> What do you think about the formulas and code source published on this
> page :
> <http://www.codeguru.com/Cpp/Cpp/algorithms/article.php/c5115/> ?
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
