[Proj] Additional up coming mods to libproj4
support.mn at elisanet.fi support.mn at elisanet.fi
Sun Oct 19 15:57:14 PDT 2008
"Gerald I. Evenden" <geraldi.evenden at gmail.com> kirjoitti:
> Besides the inverse material for some projections I took a couple of minutes
> to add the proj_initstr(chr *) entry to the library as an alternative to
> proj_init(int, char **);  In addition, each string field of the later entry
> may have multiple white-space separated projection options in the string.
> The net result of this is that one can use lproj in the following manner:
> lproj "+proj=poly ellps=intl lon_0=90w" +lat_0=40 infile
> where the ellps= and lon_0= options are processed properly along with proj=
> and lat_0=.  Remember that the "+" part of the options is only necessary for
> [l]proj to identify the runline parameter as a libproj option and not a
> filename.
> For those who use the library directly:
> P=proj_initstr("proj=poly ellps=intl lon_0=90w lat_0=40");
> may be used as an alternative to proj_init and is processed the same as the
> lproj example.
> I believe that Warmerdam has done something similar with his value added
> releases.
I have seen a French initialization file with
+title=is something with white spaces
This problematic for me, since I am used to the habbit to never have any
white space in proj.4 statements. Example of the french file follows:
<FANGA84> +title=MOP84 (Fangataufa 1984) +proj=geocent +towgs84=150.5700,158.3300,118.3200 +a=6378388.0000 +rf=297.0000000000000 +units=m +no_defs <>
Better would maybe be to put it like:
+title=<something between some markers with white spaces in it> +etc.....
Regards: Janne.
