[Proj] PROJ 4.6.1 Released
Mon Sep 1 08:51:17 PDT 2008
Folks,
I have promoted the PROJ 4.6.1 RC3 to being the PROJ 4.6.1 final release
since there don't seem to be any serious problems with it.  From the news
file:
4.6.1 Release Notes
  o Upgraded to EPSG 6.17 version for nad/epsg.  Also corrected the precision
    problem introduced in the last version.
  o Added logic for tmerc projection to fail rather than return crazy results
    if more than 90 degrees away from the central meridian (#5).  This change
    may only be temporary till a more comprehensive solution is found.
  o Fixed handling of extra text in cs2cs.
  o Renamed INSTALL to INSTALL.TXT.
  o The eqc projection has been generalized to include a latitude of origin.
  o Added the glabsgm (Gauss Laborde / Sphere Geometric Mean) projection,
    and gstmerc variation.
  o nad/IGNF init catalogue created.
  o added the ntf_r93.gsb datum shift file.
  o Add /Op in nmake.opt compile options to avoid VC7 optimization bug (#12)
  o Fix testvarious test script so it works properly when grid files available
Download it from:
   http://download.osgeo.org/proj/proj-4.6.1.tar.gz
   http://download.osgeo.org/proj/proj-4.6.1.zip
I have also added a redirect from http://proj.osgeo.org/ to our
trac web site, and I'd like to consider this url our 'public identity'
in the future.
Best regards,
