[Proj] cs2cs output file
Wed Sep 24 11:00:12 PDT 2008
Rich Westfall wrote:
> Hello,
> I’m trying to get cs2cs script to pass other fields besides the XYZ
> from an input text file out to a text file but only seem to be getting
> the xyz to come over and nothing else.
> Here is the transformation.
> cs2cs +init=epsg:2227 +to +init=epsg:4326 -f '%.4f' -s c:\proj
> \test.txt >c:\proj\example.txt
> Which is passing the data correctly just not the other fields. Fields
> are seperated by white space.
> I have been using the win32 executable.
> I'm not sure what I am doing wrong.  How do I get the other fields to come
> over?
> Thank you for any help,
Rich,
This was broken in the past in cs2cs and was fixed for the 4.6.1 release.
Upgrade if that is practical.
Best regards,
