[Proj] Terminology: what should I call 60 nautical miles?
strebe at aol.com strebe at aol.com
Mon Apr 27 13:02:03 PDT 2009
Your original instinct seems correct: one degree of arc. That is, after all, the entire reason you are interested in 60 nautical miles, is it not? Because it equates to a degree of arc on the spherical model? If you apply some other terminology to it then you have destroyed the reason for the unit. Or have I missed some other significance?
Regards,
— daan Strebe
-----Original Message-----
From: Mikael Rittri <Mikael.Rittri at carmenta.com>
To: proj at lists.maptools.org
Sent: Mon, 27 Apr 2009 4:12 am
Subject: [Proj] Terminology: what should I call 60 nautical miles?
Hello,
I would like a term for the length unit that is 60 nautical miles.
This length unit would approximate one degree of
arc distance, in the same way as one nautical mile
approximates one minute of arc distance.
I have thought of the phrase "degree of arc distance"
(which I think agrees, more or less, with how Snyder uses this phrase)
but some of my colleagues dislike it.
I have also thought of the phrase "exēntanautical mile",
from Greek "exēnta" = 60, but...
Mikael Rittri
Carmenta AB
SWEDEN
www.carmenta.com
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090427/eda87b95/attachment.html>
