[Proj] ITRF96/UTM 36N conversion
fernandohoze muranyum at yahoo.com
Fri Aug 7 07:07:19 PDT 2009
Hello,
I would like to convert coordinates in ITRF96 / UTM-36N format (measured
with DGPS) to latitude and longitude values that I can use with Google Maps.
I tried to do the conversion using proj but I couldn't do it. What command
should I use for this?
This is what my coordinates file looks like:
2   4415699.244828   482321.027219   950.950000   5 | 2 | 1.400
3   4415697.320372   482321.307750   951.050000   5 | 2 | 1.400
4   4415696.356924   482321.975236   951.050000   4 | 2 | 1.000
This is what I want:
2   39.8911748   32.7932165
3   39.8911574   32.7932198
4   39.8911488   32.7932277
I also would like to find the distance (in meters) between two points whose
ITRF96 / UTM-36N coordinates are known. I googled it but I didn't find
anything about it. Can you please help me with this?
Thanks.
View this message in context: http://n2.nabble.com/ITRF96-UTM-36N-conversion-tp3404575p3404575.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
