[Proj] Verification of inverse step in projection
José Luis García Pallero jgpallero at gmail.com
Sat Dec 12 05:44:10 PST 2009
I'm a new proj user and I have a doubt about the verification of
inverse step in projection. As the manual says (proj.4.3.pdf, page
41):
"Some projections do not have inverse capability; a state that can be
determined by proj->inv==0."
But when I try to test:
#include<proj_api.h>
projPJ pjStruct;
pjStruct = pj_init_plus("+proj=tcc +ellps=clrk66 +lon_0=90W");
if(!pjStruct)
if(pjStruct->inv==0)
At compilation time I obtain the error:
prueba.c: In function ‘main’:
prueba.c:22: warning: dereferencing ‘void *’ pointer
prueba.c:22: error: request for member ‘inv’ in something not a
structure or union
It says that inv is not a member of the projectios struct.
What is the correct way to check if a projection has inverse step?
Thanks
(o<
V_/_
Use Debian GNU/Linux and enjoy!
