[Proj] Verification of inverse step in projection
Roger Oberholtzer roger at opq.se
Sun Dec 13 04:38:04 PST 2009
On Dec 12, 2009, at 2:44 PM, José Luis García Pallero wrote:
> Hi,
> I'm a new proj user and I have a doubt about the verification of
> inverse step in projection. As the manual says (proj.4.3.pdf, page
> 41):
> "Some projections do not have inverse capability; a state that can be
> determined by proj->inv==0."
> But when I try to test:
> #include<proj_api.h>
> projPJ pjStruct;
Perhaps:
projPJ *pjStruct;
as pj_init_plus returns a pointer.
> pjStruct = pj_init_plus("+proj=tcc +ellps=clrk66 +lon_0=90W");
> if(!pjStruct)
> if(pjStruct->inv==0)
> At compilation time I obtain the error:
> prueba.c: In function ‘main’:
> prueba.c:22: warning: dereferencing ‘void *’ pointer
> prueba.c:22: error: request for member ‘inv’ in something not a
> structure or union
> It says that inv is not a member of the projectios struct.
> What is the correct way to check if a projection has inverse step?
> Thanks
> jgpallero at gmail.com
> (o<
> V_/_
> Use Debian GNU/Linux and enjoy!
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Roger Oberholtzer
OPQ Systems / Ramböll RST
Ramböll Sverige AB
Kapellgränd 7
P.O. Box 4205
SE-102 65 Stockholm, Sweden
Office: Int +46 8-615 60 20
Mobile: Int +46 70-815 1696
And remember:
It is RSofT and there is always something under construction.
It is like talking about large city with all constructions finished.
Not impossible, but very unlikely.
