[Proj] Verification of inverse step in projection
José Luis García Pallero jgpallero at gmail.com
Sun Dec 13 10:13:42 PST 2009
2009/12/13 Roger Oberholtzer <roger at opq.se>:
>>> Perhaps:
>>> projPJ *pjStruct;
>>> as pj_init_plus returns a pointer.
>>>> pjStruct = pj_init_plus("+proj=tcc +ellps=clrk66 +lon_0=90W");
>>>> if(!pjStruct)
>>>> if(pjStruct->inv==0)
>> But pj_init_plus() can't know if you will use the forward or the
>> inverse step.
> These are two different issues:
> 1) You have a syntax error, which I tried to explain. That must be
> corrected no matter.
But the correct way of projPJ declaration is projPJ pjStruct because,
actually, projPJ is internally a pointer, as you can see in
http://trac.osgeo.org/proj/browser/trunk/proj/src/proj_api.h#L53
My problem is that I need to know if any projection has inverse step,
because some of them have not. As I posted in my first message, the
PROJ4 manual says that this can be checked as pjStruct->inv==0
(inverse step do not exist). But my compiler says that the member
'inv' do not exists in pjStruct.
(o<
V_/_
Use Debian GNU/Linux and enjoy!
