[Proj] Convert X and Y to Lat and Lon
don_nell don_nell at yahoo.com
Thu Dec 17 09:49:23 PST 2009
Hamish,
That's amazing. Thank you so much.
I've been struggling with this for a few days now and finally have the
answer.
Would you happen to know how to go the other way too? If I have the Lat and
Lon, how would I know the X and Y.  I'm still very new to this.
Thanks again for your time.
Don
hamish-2 wrote:
> don_nell wrote:
>> I'm very new to mapping and I'm trying to use cs2cs.exe
>> from Proj4 to
>> convert the X and Y values from an ESRI shape file (roads
>> from the state of
>> Georgia) into Lat and Lon coordinates.  However, I'm
>> not sure what
>> parameters I need  to accomplish this.
>> I've gotten pretty close using the parameters below (plus
>> or minus a city
>> block), but I'm sure I could do better.
>> +proj=tmerc +units=us-ft +datum=NAD83 +lat_0=-1.77517
>> +lon_0=-83.5 +k=0.9999
>> +x_0=0.0
>> The "+lat_0" parameter was derived by trial and error.
>> Can anyone tell me the correct parameters to use to make
>> this work?
>> The contents of the associated .prj file are as follows.
>> Thanks in advance.
>> Don
> PROJCS["NAD_1983_Georgia_Statewide_Lambert"
> ,GEOGCS["GCS_North_American_1983"
> ,DATUM["D_North_American_1983"
> ,SPHEROID["GRS_1980",6378137.0,298.257222101]]
> ,PRIMEM["Greenwich",0.0]
> ,UNIT["Degree",0.0174532925199433]]
> ,PROJECTION["Lambert_Conformal_Conic"]
> ,PARAMETER["False_Easting",0.0]
> ,PARAMETER["False_Northing",0.0]
> ,PARAMETER["Central_Meridian",-83.5]
> ,PARAMETER["Standard_Parallel_1",31.41666666666667]
> ,PARAMETER["Standard_Parallel_2",34.28333333333333]
> ,PARAMETER["Latitude_Of_Origin",0.0]
> ,UNIT["Foot_US",0.3048006096012192]]
> try:
> +proj=lcc
> +datum=NAD83
> +x_0=0.0
> +y_0=0.0
> +lon_0=-83.5
> +lat_1=31.41666666666667
> +lat_2=34.28333333333333
> +lat_0=0.0
> +units=us-ft
> that is just by hand, I think there is some util which comes
> with the gdal(?) source code for translating WKT to +proj4
> syntax.
> there is one South Georgia LCC in the EPSG file, but it's a
> bit different.
> Hamish
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
View this message in context: http://n2.nabble.com/Convert-X-and-Y-to-Lat-and-Lon-tp4181089p4182536.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
