[Proj] Normal vector to a point on an Earth ellipsoid
Gerald I. Evenden geraldi.evenden at gmail.com
Tue Feb 3 09:02:11 PST 2009
On Tuesday 03 February 2009 10:54:22 am Ung wrote:
> Hi All,
> Is there a function within Proj4 that would return a representation of a
> normal vector to a point on an Earth ellipsoid? Perhaps something like:
> getNormal( projPJ my_cs, double x, double y, double z )
> Would be grateful for any clues!
> -ung
Sounds like an ENU coordinate but that is *not* part of a projection
operation.  I will probably put a function like that in my geodesy library
but it is more related to XYZ geocentric system with a translation rotation
involved---translation of the geocentrin origin to a local point and rotation
about this point.
But an ENU has *nothing* to do with projections as the XY (Easting-Northings)
in projections have no relationship to the XY in EN even though the EN stands
for Easting-Northing.
It is unfortunate that the ENU designers stole the projected space
nomenclature.
If you are just concerned with a z value you would have to "pass it around"
the projections operation.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
