[Proj] gaus-kruger projection
support.mn at elisanet.fi support.mn at elisanet.fi
Fri Feb 6 00:58:31 PST 2009
Hello,
I would swap the pj_tmerc.c (or what it is) to pj_gauss.c and compile it again.
It may need some additional fixing in some init areas... ??
Regards: Janne.
Pieter Bosch [pieter.bosch at za.saabgroup.com] kirjoitti:
> Hi,
> Does anyone know if proj4's  command prompt app can do gaus-kruger
> projection and if so what is the parameters to use. How would the
> following statement have to change to be in Gaus-kruger.
> +proj=tmerc +ellps=WGS84 +lon_0=12 +x_0=500000
> I've seen a pj_gauss.C file  but I cant see any abbreviation in the
> projection list that identifies GAUSS-Kruger. Please help
> Cheers
> pieter
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
