[Proj] Projections API Reference
Fri Feb 13 16:49:41 PST 2009
Gerald I. Evenden wrote:
> On Friday 13 February 2009 1:50:02 pm Frank Warmerdam wrote:
>> Folks,
>> With some contributions from Markus I have started writing up more detailed
>> reference docs for the PROJ.4 API at:
>>    http://trac.osgeo.org/proj/wiki/ProjAPI
>> This is intended to supercede the pj_init(3) man page which was quite
>> incomplete.  Extensions and improvements are welcome.
>> Best regards,
> I notice that one of the things you completely throw away is the flexibility
> associated with using structures to define geographic and Cartesian
> coordinates.
> Although, original proj and current libproj4 simply define LP as struct
> {double lam, phi} my usage of LP was expanded to include h.  By using
> stuctures, applications can adopt updates much more simply.
Gerald,
I would suggest that the way structures were used, an update to the
structures to include h would have resulted in undefined "h" values being
passed into PROJ from old applications.
 >  Similarly, XY
> simply goes to XYZ.  One can also associate ellipoid with the structure.
I'm not sure what you mean about associating an ellipsoid with the structure.
> And for shame, you a C++ programmer an all should know better.
I'm sure that C++ enthusiasts would have suggested substantially different
approaches, but I was not inclined to add a C++ dependency to PROJ.4 at
the time I was extending the API (with pj_transform() and pj_init_plus()
for instance).
I would also humble suggest that many of these points on programming
style are subjective and there is often not a right or wrong.
> There is more to criticise but I don't think it is worth the effor.
My email wasn't really a call for API criticism.  Just a pointer to
a resource, and encouragement for others to extend/correct the docs.
Best regards,
