[Proj] How to transform between NAD83 HARN/HPGN and WGS84
Clifford J Mugnier cjmce at lsu.edu
Thu Feb 19 10:24:35 PST 2009
Mr. Friesen:
Such questions regarding geodetic-accuracy transformations in Colorado are best directed to the U.S. National Geodetic Survey.  NADCON indeed does have NAD83 HARNHPGN files, and can provide the necessary operations either on-line or through a download.  The same goes for current versions of CorpsCon.  Both solutions are not commercial and both are free.
Go to www.NOAA.NGS.gov and you'll get your problem solved for free courtesy of the U.S. Government.  A Google search will get you to the current version of CorpsCon.
C. Mugnier
LSU
From: proj-bounces at lists.maptools.org on behalf of Aaron Friesen
Sent: Thu 19-Feb-09 11:20
To: proj at lists.maptools.org
Subject: [Proj] How to transform between NAD83 HARN/HPGN and WGS84
Everyone,
I checked the archives for the past year and did not find an
answer to this.  Google did not provide me with any leads
either.
I have data in NAD83 HARN for Colorado.  I need to take the
data into the field as WGS84, update it/add to it, and get
it back as NAD83 HARN for Colorado.  The data I am collecting
has sub-foot accuracy, so "close" is not good enough.
The information on the grid files does not address the
HARN/HPGN question.
Is this type of transformation with the accuracy I need
possible with Proj?
Are HARN grid files available or are towgs84 settings defined
for the various HARN areas?
Or am I stuck looking for an alternative, commercial solution?
Thank for your assistance.
Aaron
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090219/8de982ea/attachment.html>
