[Proj] Modern C functions
Thu Feb 26 19:31:58 PST 2009
Gerald I. Evenden wrote:
> This is a quick probe of the programming types in this group.
> In finalizing Rel. 2.0 of geodesic and libgeodesy I ran across functions under
> the <string.h> heading which are not in the typical (read Harrison & Steele)
> library references: strcasecmp and strncasecmp.  These are noted in the Gnu
> man.3 as Posix 2001 standard routines.  Obviously, these two routines replace
> strcmp and strncmp and make comparisons case independent.
> As soon as I became aware of them I have included them to eliminate the nasty,
> nasty fact of having to shift when typing in WGS84 and can now use
> ellps=wgs84.
> A little net browsing has yielded mixed results as to how well know these
> functions are.
> Thus my question here is: do non-Gnu C compilers used by this audience
> recognize these functions?
It's not an issue for the compiler, but for the standard library.
The are specified by POSIX, but not by ANSI C (neither C89 nor C99).
As others have already pointed out, Windows doesn't provide them.
Also, gcc won't recognise them if you use -ansi and don't explicitly
add the POSIX feature macros, e.g. -D_POSIX_SOURCE. I don't know
whether uclibc has them.
Also, bear in mind that the behaviour depends upon the locale; using
them for strings containing anything other than alphanumeric
characters is problematic.
