[Proj] Ellipsoid data sources
Mon Jan 5 14:39:08 PST 2009
Gerald I. Evenden wrote:
> An aside to this issue: the NIMA pdf Janne ref'ed on local geodetic systems
> notes "ID codes" with it appendix of ellipoid tables.  For example: WGS 84
> was code "WE".
> Reference may be in the pdf but I could not locate it.  It just refers
> to "standardized two letter code."
> Does anyone know where and who is responsible for these codes?
Gerald,
I'm familiar with these codes from the datum and ellipsoid information
distributed with GeoTrans produced at NIMA/NGA.  So I assume they are
based on some military coordinate system standard.
Best regards,
