[Proj] Geo Transfoms and calculations
Gerald I. Evenden geraldi.evenden at gmail.com
Tue Jan 6 14:32:48 PST 2009
On Monday 05 January 2009 11:29:25 pm Charles Wilson wrote:
> Charles Karney wrote:
> > Gerald I. Evenden wrote:
> >> 5.  What's a poor jerk like me supposed to do?  For example, on the
> There's a similar BSD-licensed library called editline, which is a
> "autotool- and libtoolized port of the NetBSD Editline library
> (libedit)." In addition to its own native el_* interface, it provides a
> mostly-complete implementation of the rl_* readline interface in
> editline/readline.h.
> http://thrysoee.dk/editline/
> It depends on lib[n]curses or libtermcap (but then, so does readline
> usually).
This seems to work OK on the test file level but the documentation is pretty
grim.  Also support seems to be spread into several, discontinuouis sites.
The need for readline or something like it is so universal it should be
supported under a more general license.  Can you imagine using 'bash' or any
of the other shell programs without it?  Usage applies to any command line
program.  Just like the program I am working on: without it if you make an
error typing in a line, you have to do the whole line over; if you made an
error on the last command, again, type it over.  Without it you can't back up
and make a quick fix.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
