[Proj] Plog GPS Coordinate to Screen
Claudio Bisegni cbisegni at gmail.com
Thu Jan 8 22:43:25 PST 2009
Hi janne, thanks for replay.
I have done some google search to find a good init param to do the
work but whitout a great success. Have you some example for proj
initialization to get this work,
Thank you in advanced.
Claudio
Il giorno 09/gen/09, alle ore 02:13, support.mn at elisanet.fi ha scritto:
> Hello,
> you can use Proj.4 to calculate the map projection (forward or
> inverse)
> to you. It can also do datum conversions relative WGS84.
> regards: Janne.
> Claudio Bisegni [cbisegni at gmail.com] kirjoitti:
>> Hi, i'm new to Proj lib. I wan't to write a software to plog gps
>> coordinate to the screen. How can i setup proj to do this work? thank
>> in advanced.
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
