[Proj] Finally: geodesic-1.0 is available!
Gerald I. Evenden geraldi.evenden at gmail.com
Fri Jan 9 09:04:59 PST 2009
On Friday 09 January 2009 11:52:48 am OvV_HN wrote:
> ----- Original Message -----
> From: "Charles Karney" <ckarney at sarnoff.com>
> To: <geraldi.evenden at gmail.com>
> Cc: <proj at lists.maptools.org>
> Sent: Friday, January 09, 2009 12:45 AM
> Subject: Re: [Proj] Finally: geodesic-1.0 is available
> > If I don't hear of a good geodesic test set, I'm tempted to construct
> > one myself (no promises, though).
> By the way, I simply don't believe in test sets with millions of random
> test points.
> With some mathematical knowledge you know where the asymptotes,
> singularities and other irritating point are. Some tens or hundreds of test
> points around these, coupled with some random test points in all octants of
> the globe, should be sufficient.
I whole heartedly agree with you.  The late John Snyder seemed to be another
believer of thowing zillions of test points at a projection.  Some time ago
when downloading a copy of GCTP stuff I couldn't believe the time it took.
The download was a monster and it turned out that it was nearly all test
points for the various state plane systems.
> > On the subject of the transverse Mercator projection, I'm about 2 weeks
> > away from posting a new version of my "exact" TM program with much more
> > exhaustive testing (see above), a more careful treatment of singular
> > points, etc.  Stay tuned.
No! No! No!  I thought we had beat that dead horse to a pulp.  ;-)
> Nice!
> I've already resolved the lat=90d problem in the inverse (calculation of
> zeta where snv==0 and (cnu==0 or dnv==0) ), but there are probably some
> more problems? I'll stay tuned!
> Oscar van Vlijmen
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
