[Proj] Finding PROJ_LIB from application
Thu Jan 15 08:07:41 PST 2009
Roger Bivand wrote:
> Hi,
> Is there any way to query the system for the path to lib - effectively the
> path value in sysname in pj_open_lib.c, line 184? From inside R, I'd like
> to be able to show which path is being used.
Roger,
No, I do not believe there is any way to to do this.  You can set the
PROJ_DEBUG environment variable (to any value) to see some debug output
to stderr when pj_open_lib() tries to open files but I don't imagine that
gives what you want.
Best regards,
