[Proj] Problems using grid shift files
Mikael Rittri Mikael.Rittri at carmenta.com
Thu Jan 22 07:58:53 PST 2009
Dear Stefan,
This is not the answer you are looking for, but maybe it helps.
>From the source code in src/pj_datum_set.c, my impression
is that +nadgrids takes precedence over +towgs84, at least
in Proj4 (perhaps not in OGRSpatialReference etc.).
That would mean that in your definition of CRS 902056,
where you use both +towgs84=674.374,... and +nadgrids=@null,
the +towgs84 would be ignored and +nadgrids=@null would be
used, which is the same thing (as far as I understand) as
saying that the longitude/latitude in CRS 902056 is the same
as longitude/latitude in WGS84.
But that's not your intention, is it?
The datum of EPSG:2056 is CH1903+, and the datum of
EPSG:21781 is CH1903 (without the +).
I thought CH1903+ was some kind of improved version of CH1903,
with less distortion, although I don't know if your gridshift
file is intended for CH1903 or for CH1903+.
Anyway, I don't the see the reason for using +nadgrids=@null
in your definition of CRS 902056.  I would have expected either
the +towgs84 parameter or the +nadgrids=chenyx06.gsb.
Best regards,
Mikael Rittri
Carmenta AB
Box 11354
SE-404 28 Göteborg
Visitors: Sankt Eriksgatan 5
SWEDEN
mikael.rittri at carmenta.com
www.carmenta.com
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Ziegler Stefan
Sent: den 19 januari 2009 17:00
To: proj
Subject: [Proj] Problems using grid shift files
Dear List
we have some problems using grid shift files. We are using a grid shift file which was developed by the Swiss Federal Office of Topography [1]. We just duplicated epsg 21781 (to 921781) and 2056 (to 902056) in the epsg file and added "+nadgrids=chenyx06.gsb" and "+nadgrids=@null":
21781:
+proj=somerc +lat_0=46d57'08.66"N +lon_0=7d26'22.50"E +ellps=bessel +x_0=600000 +y_0=200000 +towgs84=674.374,15.056,405.346 +units=m +k_0=1 +no_defs
2056:
+proj=somerc +lat_0=46d57'08.66"N +lon_0=7d26'22.50"E +ellps=bessel +x_0=2600000 +y_0=1200000 +towgs84=674.374,15.056,405.346 +units=m +k_0=1 +no_defs
921781:
+proj=somerc +lat_0=46d57'08.66"N +lon_0=7d26'22.50"E +ellps=bessel +x_0=600000 +y_0=200000 +towgs84=674.374,15.056,405.346 +units=m +nadgrids=chenyx06.gsb +k_0=1 +no_defs
902056:
+proj=somerc +lat_0=46d57'08.66"N +lon_0=7d26'22.50"E +ellps=bessel +x_0=2600000 +y_0=1200000 +towgs84=674.374,15.056,405.346 +units=m +nadgrids=@null +k_0=1 +no_defs
4326:
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
904326:
+proj=longlat +ellps=WGS84 +datum=WGS84 +nadgrids=@null
Here are the results:
21781 -> 2056: correct!
921781 -> 90256: correct (with grid shift file)!
but:
921781 -> 2056: wrong!
921781 -> 4326: wrong!
921781 -> 904326: wrong!
Is the grid shift only applied if the destination definiton has a "+nadgrids=@null"? But then why is the transformation to 904326 not correct? Has this something to do with this bug report [2]? Or I'm just mixing up some parameters? Same results with Proj 4.5 and 4.6.1. Any help is appreciated.
regards
Stefan
[1]: http://www.swisstopo.admin.ch/internet/swisstopo/en/home/topics/survey/lv03-lv95/chenyx06/distortion_grids.html
[2]: http://trac.osgeo.org/proj/ticket/22
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler at bd.so.ch
http://www.so.ch
