[Proj] Problems using grid shift files
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Jan 23 07:11:56 PST 2009
On Fri, 23 Jan 2009, Mikael Rittri wrote:
> I think cs2cs normally assumes that a grid shift file will transform a national datum to WGS84.
> So I don't know how chenyx06.gsb can be used by cs2cs, but perhaps some pipe
> construction could be used.
Specify the gridshift file as part of the PROJ.4 description of the CH1903
system, and use a +towgs84=0,0,0 datum parameter set for the CH1903+
location. Something along those lines should work I think, but the
co-ordinates would need to be transformed again to get to WGS84.
Paul
