[Proj] Lat-Lon values under different ellipsoides
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Jan 26 02:54:27 PST 2009
This is something I have long been banging my head against. I think it
is a bug, but I am not sure. If I take a lat-lon value, computed on a
particular ellipsoid, and convert it to the lat-lon value on another
ellipsoid, I should get a different value, right? (e.g. cs2cs
+proj=longlat +ellps=bessel +to +proj=longlat +ellps=WGS84). PROJ4
always gives the same value, but I have an extensive list of coordinates
of church towers in the Netherlands with their lat-lon values in 1850,
based an a slightly smaller ellipsoid than we use nowadays, and the
lat-lon of the same towers derived from our modern RD-system, based on
the Bessel-ellipsoid, and without the WGS84 correction. There is a
systematic difference of about 50 meters. If I do the same computation
with the projected coordinates, I get the correct answer. Moreover, in
that case the transformation changes when I change the
ellipse-parameter, something that does not happen with lat-lon coordinates.
So, is this a bug in PROJ? If so, can someone with geodetic experience
here explain to me how people can get different lat-lon values for the
same point, based on astronomical measurements?
Thanks,
Jan
