[Proj] gps lat/long to x/y rotated issue
Claudio Bisegni cbisegni at gmail.com
Mon Jan 26 03:06:35 PST 2009
Thank you Janne,
i'll try.
Claudio
On 26/gen/09, at 11:44, support.mn at elisanet.fi wrote:
> Hello,
> either you have to rotate it 90 degrees back - or swap y to x and x
> to -y (or
> somthing similar, maybe add some false n and e values and experiment
> with signs).
> Regards Janne.
> Claudio Bisegni [cbisegni at gmail.com] kirjoitti:
>> Hi folk,
>> i use this init string found on google, to make the work in object:
>> +title= Google Mercator EPSG:900913  +proj=merc +a=6378137 +b=6378137
>> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
>> +nadgrids=@null
>> +no_defs
>> It's work well except that the graf is rotated of 90° clockwise.
>> Any one has na idea? I'm new to proj..
>> Thanks in advanced.
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
