[Proj] Lat-Lon values under different ellipsoides
Tue Jan 27 07:41:20 PST 2009
Jan Hartmann wrote:
> Yes, this works, thanks Frank. I added the same datum definition to both
> input and output proj definitions, and now the transformation is
> correct. One very minor point: if I add the Datums in the form
> +proj=longlat +datum=WGS84 +ellps= ...  +to +proj=longlat +datum=WGS84
> +ellps=..., no ellipse transformation is computed. If I add the
> definitions in the form of a +towgs84 string (the same for both
> projections),  the ellipses are computed correctly. There is probably
> some if-statement somewhere that skips the datum (and ellipse!)
> computation when both datums are the same. Would it be possible to
> remove that if-statement when ellipse-parameters are also given?
Jan,
It is not meaningful to use +datum=WGS84 and an ellipse setting that is
not WGS84.  The +datum=WGS84 expands internally into
+towgs84=0,0,0 +ellps=WGS84 so your declaration will end up with two ellipse
settings and which one gets selected will depend on order - a rather unstable
situation!
Best regards,
