[Proj] Whew, in spite of the damnable distribution software
Roger Oberholtzer roger at opq.se
Mon May 18 12:58:35 PDT 2009
On May 18, 2009, at 9:28 PM, Gerald I. Evenden wrote:
>>> Just an added note: in the case of Windows why not just distribute
>>> a DLL
>>> and *.exe's.?  If someone want the sources, then they are
>>> responsible for
>>> dealing with the configure for DOS.
>> That is how it's usually done, but hen you need to compile them.
>> MinGW+Msys is on option, or cygwin with the -mingw flag (to get
>> binaries
>> that don't depend on cygwin)
>> -Chris
> A quick look at the MinGW+MSYS web site makes it seem like the choice.
> Are there any other comments on this suggestion?  Especially from
> nay-sayers
> and critics.
> One thing that comes to mind: I have a 64 bit machine.  How is that
> going to
> confuse the above operations?  Compile different exe's?
> Other details about pthread and GSL library options.  How to handle
> said
> options has to be dealt with.
> Thanks for the suggestion.
You might also consider the openSUSE build service, which can make the
various packages automatically. This includes many Linux platforms as
well as Windows. You do not need to maintain the systems on which you
want to build things.
Roger Oberholtzer
OPQ Systems / Ramböll RST
Ramböll Sverige AB
Kapellgränd 7
P.O. Box 4205
SE-102 65 Stockholm, Sweden
Office: Int +46 8-615 60 20
Mobile: Int +46 70-815 1696
And remember:
It is RSofT and there is always something under construction.
It is like talking about large city with all constructions finished.
Not impossible, but very unlikely.
