[Proj] WGS84 parameters in epsg:31370 and 28992 (Belgian and Dutch coordinate systems)
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Nov 9 02:02:36 PST 2009
In the epsg-file in Proj-4.7.0, the Belgian coordinate system (31370)
has a +towgs84 clause, and the Dutch one (28992) hasn't. Is there any
reason for this? EPSG:28992 is much more usable *with* the +towgs84
parameter, as conversions to WGS84 latlon (EPSG:4326)  won't be correct
without it.  The same goes for conversions between Dutch and Belgian
coordinates: they *both* need the  +towsg84 parameter:
$ cs2cs +init=epsg:28992 +to +init=epsg:31370 # (only one projection or
none  with +towgs84, incorrect transformation)
300000 180000
368686.96       35802.01 0.00
$ cs2cs +init=epsg:28992 +to +init=epsg:31370 # (both projections with
+towgs84, this one is correct)
300000 180000
368729.27       35841.07 -301.04
My impression is that ellipse conversions (bessel to intl in this case)
are only done when both projections have a +towgs84 string. Is this
correct? I know that this is the case for lat-lon values (see Frank's
response at:
http://lists.maptools.org/pipermail/proj/2009-January/004303.html), but
is this also the case for projected coordinate systems? Doesn't look
right to me.
Jan
