[Proj] ESRI:102026 with +lat_0=0 +lon_0=0: bug or feature?
OvV_HN ovv at hetnet.nl
Fri Nov 13 00:54:46 PST 2009
----- Original Message -----
To: <proj at lists.maptools.org>
Sent: Friday, November 13, 2009 7:35 AM
Subject: [Proj] ESRI:102026 with +lat_0=0 +lon_0=0: bug or feature?
> Greetings!
> spatialreference.org states that central meridian of this projection is
> 95:
>    PARAMETER["Central_Meridian",95],
> (See http://spatialreference.org/ref/esri/102026/)
> Howerver, in esri file bundled with proj4 its parameters are:
> +proj=eqdc +lat_0=0 +lon_0=0 +lat_1=15 +lat_2=65 +x_0=0 +y_0=0
> +ellps=WGS84 +datum=WGS84 +units=m  no_defs
> +lon_0 should be 95, not 0, shouldn't it?
Yep, and lat_0 = 30, according to ESRI documentation.
Oscar van Vlijmen
