[Proj] Mémoire sur la représentation des surfaces et les projections des cartes (Auguste Tissot, 1881)
Paul B. Anderson pbander at cavtel.net
Sun Nov 15 08:05:50 PST 2009
- Oscar,
There must be a problem with the way the post arrived to you, and is broken.
Before I sent the original post I logged totally out of Google to test the
link - and it worked. All the text that you say is missing in the copy you
found is in the one at google books. In your case I would suggest going to
Google Books and do an author search. You may find the better document that
way.
- Paul
----- Original Message -----
To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Sent: Sunday, November 15, 2009 10:46 AM
Subject: Re: [Proj]Mémoire sur la représentation des surfaces et les
Sent: Sunday, November 15, 2009 4:04 PM
Subject: [Proj] Mémoire sur la représentation des surfaces et les
- Hi everyone,
If there is any interest here, Google has scanned the French text:
By Auguste Tissot (1881)
http://books.google.com/books?id=a5YOAAAAYAAJ&printsec=frontcover&dq=Auguste+tissot&ei=LAoAS-_lFaD2ygT9vOz3Dg#v=onepage&q=&f=false
Note that in Google's PDF download version there are about 7 blank pages
between the book cover and where the text begins.
REPLY:
Interesting! Mr. Tissot was the inventor of the Tissot indicatrix.
I knew that, but it's amusing to see a key publication.
I couldn't get it from Google; probably 'cos I'm not registrered?
I got the Google pdf from the Internet Archive:
http://www.archive.org/details/mmoiresurlarepr00tissgoog
See the link "All Files: HTML".
BTW: page 198 is unsharp at the right.
Pages 199-285 are apparently forbidden - they are not in the pdf.
There's no copyright on the book, so why should Google omit these pages?
Oscar van Vlijmen
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
