[Proj] Mémoire sur la représentation des surfaces et les projections des cartes (Auguste Tissot, 1881)
Karney, Charles ckarney at Sarnoff.com
Sun Nov 15 09:23:00 PST 2009
Thanks for the pointer.  Indeed Google Books is a treasure trove for old
books.  One other oldie is
    Johann Heinrich Lambert 1772
    Beyträge zum Gebrauche der Mathematik und deren Anwendung,
    http://books.google.com/books?id=sf82AAAAMAAJ
This is only part 3; I couldn't find the other parts on Google.
I have found 2 problems with Google Books
(1) The indexing of books is rather hit-or-miss.  This is particularly a
problem when searching for journal articles (some journals appear with
variant of the title, the volume number isn't listed in the search
results, etc.).
(2) The scanning is sometimes hit-or-miss.  Some pages are accidentally
skipped.  Fold-out pages of figures are not folded out.  Etc.
For this reason, it would be great if someone could start compiling a
bibliography of online books and papers on projections.  I started such
a bibliography for geodesics at
    http://trac.osgeo.org/proj/wiki/GeodesicCalculations#TheHistory
(which now has 75 entries) and several of the works I include (by Gauss,
Helmert, etc.) deal with projections.
BTW, the URL for Tissot's book can be shortened to
    http://books.google.com/books?id=a5YOAAAAYAAJ
  --Charles
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] On Behalf Of Paul B. Anderson [pbander at cavtel.net]
Sent: Sunday, November 15, 2009 10:04
To: PROJ.4 and general Projections Discussions
Subject: [Proj] Mémoire sur la représentation des surfaces et les projections des cartes (Auguste Tissot, 1881)
- Hi everyone,
If there is any interest here, Google has scanned the French text:
By Auguste Tissot (1881)
http://books.google.com/books?id=a5YOAAAAYAAJ&printsec=frontcover&dq=Auguste+tissot&ei=LAoAS-_lFaD2ygT9vOz3Dg#v=onepage&q=&f=false
Note that in Google's PDF download version there are about 7 blank pages
between the book cover and where the text begins.
Take care,
- Paul
