[Proj] Conversion help
` ` teletautala at hotmail.com
Tue Sep 8 16:04:24 PDT 2009
I believe if I use "proj -I +init=nad83:4302 +units=us-ft" with the input file it should work.  I have tested the conversions against the corpscon program and they work.  Thank you for your help.
-Daniel
> From: ovv at hetnet.nl
> To: proj at lists.maptools.org
> Date: Sat, 5 Sep 2009 11:06:32 +0200
> Subject: Re: [Proj] Conversion help
> ----- Original Message -----
> From: "` `" <teletautala at hotmail.com>
> To: <proj at lists.maptools.org>
> Sent: Thursday, September 03, 2009 9:17 PM
> Subject: [Proj] Conversion help
> I need to convert waypoints from State Plane, NAD 83 4302 - Utah Central,
> U.S. Feet to Geographic, NAD 83.  Here is some data:
> original data:
>     7276845.40800,1473458.11800
> nad2nad conversion (nad2nad -i spcs=4302,rev,83,feet -o 83,rev -w7
> reversedConversion.txt | head -1):
>     40d8'56.1498803"N    117d22'21.7731358"W,1473458.11800
> data converted with corpscon:
>     40 17 43.03866,112 05 54.83550
> Reply:
> I think I've got part of the solution.
> Somehow your x was interpreted as zero.
> If you convert x = 0; y = 7276845.40800; to LCC without further grid
> interpolation, then you'll get
> lat = 40d 08m 56.14988s, lon = -117d 22m 21.77314s
> The Corpscon values are correct for SPCS 4302 and x = 1473458.11800; y =
> 7276845.40800;, also without grid interpolation.
> Oscar van Vlijmen
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
_________________________________________________________________
Windows Live: Make it easier for your friends to see what you’re up to on Facebook.
http://windowslive.com/Campaign/SocialNetworking?ocid=PID23285::T:WLMTAGL:ON:WL:en-US:SI_SB_facebook:082009
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090908/a43ba3e7/attachment.html>
