[Proj] Problems with EOV for Hungary (1972 Egyseges OrszagosVetuleti)
Roger Oberholtzer roger at opq.se
Tue Sep 22 23:17:08 PDT 2009
On Tue, 2009-09-22 at 17:25 +0200, Jean-Claude REPETTO wrote:
> You have forgotten to add the +towgs84 parameter to the first
> projection. Alternatively, you can use "+datum=WGS84" instead of
> "+ellps=WGS84 +towgs84=0,0,0,0,0,0,0".
This did indeed work. Thanks! I am now within 0.2 meters of the ArcGIS
calculations.
Roger Oberholtzer
OPQ Systems / Ramböll RST
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
Office: Int +46 8-615 60 20
Mobile: Int +46 70-815 1696
