[Proj] ntf_r93.gsb file corrupted
Thu Sep 24 11:49:54 PDT 2009
Cuinet Jérôme wrote:
> A question :
> Are not there some coordinate transformation tests which verifiy the
> calculations ?
> I don't know how often mistakes appears, but this type of tests don't seems
> to be diificult to construct.
Jérôme,
There are regression tests, but they do not include ntf_r93.gsb even now.
I would add the problem corrupted the file in a relatively subtle way that
would only be detected for a grid shift in some places.
In fact I see there is a testIGNF but it was commented out in the past when
it wasn't obvious to determine whether we had the supporting gsb file or not.
I am updating the Makefile.am to include the testIGNF and testntv2 checks
if the corresponding grid shift files seem to be available.  I'll produce a
new beta later today with these changes.
Note these are only run on unix systems.
 > A no-regression test could have been mandatory, no ? Some unusual functions
 > might be broken without anybody pick out it.
The word "manditory" has limited application in open source.  It is very rare
that I get paid for any PROJ.4 maintenance, and I'm only doing this because
when I took it on there was no one else willing to do it.
There is certainly room for additional PROJ.4 developers and contributors.
Best regards,
