[Proj] Numerical Precision in Proj, WKT, and everywhere
Craig Bruce
csbruce at cubewerx.com
Thu Apr 1 17:42:25 PDT 2010
"Gerald I. Evenden" <geraldi.evenden at gmail.com> wrote:
> Au contraire. When you have a number with few significant figures that have
> trailing zeroes such as "0.999600....000" any format that has sufficient
> width to contain the significant figures will preserve the significance.
> There is no rounding nor trucation problem.
Obviously, but I'm not talking about specific values that happen to
be round.
> The only hassle occurs when the the fractions are irrational such as pi,
> then there is a problem.
There's also a problem with rational fractions, like 1/60, as I showed
in the WMS example. You can easily write x = 1/60.0 in a program get a
fully precise value for whatever representation you are using, but you
can't put this expression on the proj command line (AFAIK).
> But in these situations (and probably others) the continual bouncing
> back and forth between decimal and binary should be avoided. I strongly
> suspect that there is no good reason for it anyway.
I agree that it's best to avoid unnecessary conversions, but there are
many interfaces that require text, such as the proj command-line or OGC
web interfaces. The same issue occurs with the database/application
interface with BCD. We are forced to obey the interfaces of the various
systems we wish to chain together.
Dr. Craig S. Bruce | Ph 819-771-8303 x205 | CubeWerx Inc.
Senior Software Developer | Fax 819-771-8388 | Gatineau, Québec, Canada
csbruce at cubewerx.com | http://csbruce.com/ | http://www.cubewerx.com/
"Committee, n.: A group of people that, when given the task of deciding
whether to start array indices from either 0 or 1, compromises to declare
that they shall start from 0.5." -- unknown
More information about the Proj
